Check and clean the filter inside at the bottom of the dishwasher. Make sure the spray arm rotates freely and that the holes are not clogged. If the dishwasher has a collapsable tower to shoot water into the upper spray arm, make sure it is not stuck and that nothing is blocking it from rising.
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Usually in the center of the spray arm is a wing nut. Simply unscrew this to remove the arm(s). Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up. I hope this works. If it does, please let Fixya know by rating my solution. Good luck!
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up. I hope this works. If it does, please let Fixya know by rating my solution. Good luck!
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. In the center of the sprayer arm there is usually a wing nut that unscrews easily and releases the sprayer arm. Once you have removed the arms, rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up. I hope this works. If it does, please let Fixya know by rating my solution. Good luck!
