Take out all the spark plugs and put a radiator pressre tester on the radiator and pressurize the system, then inspect each spark plug hole for coolant. you will find out what cylinder or head will need service. How did this car run before sitting? Blue smoke is not good, although it doesnt sound like you have run it long enough to verify any real cyl problems. if its smoking it may be overhaul time. and the complete engin ewill need disassembly.
Testimonial: "Great advice, I wanted to do some initial troubleshooting before rushing in to a teardown. This is the info I needed. Thanx"
Sounds like your gaskets just dried out from sitting to long same thing happend to my 350 you will probably have to replace all the gaskets and sills or the problem will continue over and over. As far as possible cracks you will want a machine shop to check that out they can find cracks so small you would never see them. Getting the motor magnifluxed is well worth the money as aposed to rebuilding it over and over.
