Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
Posted on Sep 18, 2009
When I turn on my computer, the screen(DAEWOO)shows no signal,the light stays orange?
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 18, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1411
Points
28
Check you Video Card.
Orange light shows up when i turn on
Hi , I suggest check the display video input configuration via the on-screen display menu as per the appropriate computer mainboard video out mode
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
1helpful
2answers
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
1helpful
2answers
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
3answers
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
My biewsonic va702b, when powered up flashes for one second the screen. it's bright in all the corners, just wont stay on, power light changed to orange. do I have inverter problems??
The power light turning orange means the monitor isn't getting a signal from the computer. Or the monitor has a problem. If the screen shows light in the corners, the inverter is working. (If the inverter stops there is no light at all.)
The first thing to try is connecting another monitor to make sure your computer is actually starting up. If that monitor also shows nothing, you have a computer issue to take care of. Otherwise the monitor needs service.
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
