Hi, i have a acer aspire t310 and it would not display even at bios. i reset the bios by taking the battery out, changed the ram pulled out all pci cards, took the cpu out. put thermal paste on. put everything back in except the pci cards. turned it on. and it displayed. i went into safe mode. then it froz while i was in safe mode. I restarted it and went into bios. as i went to change the boot piority it froz on me. I re did everything and it freezes before i can enter in bios. please help i need it going urgently.
Thank you
Hello Tamana
happy Holidays
It is a double cross problem, disbling your Internal Video, and put an external, must correct this problem, a PCIE card,
and if you got 2 modules of RAM, take out CAREFULLY one and test, if startup RAM is the culprit, if not, or have only a Single RAM, buy a new one, test. only 2 things are failing here, one can be RAM and the other Internal video .
Good Luck
REPLACE RAM OR VGA CARD
