SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
SOURCE: clothes are not drying completely - even when I
make sure the vent from dryer to the outside is clear. Also may have to pull back off dryer to clean all the lint from there. Make sure there is nothing covering the two vents inside the drum.
SOURCE: dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
SOURCE: Maytag Dryer timer keeps running
I have looked at your dryer schematic. The only thing that moves the timer forward towards the end of cycle is the timer motor. You are going to need a new timer, looks like they have one for 54 bucks HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: have a maytag bravos dryer
The Maytag Bravos is a good dryer and I am sorry you are experiencing trouble already with it. Since you are not drying, it is probably either the heating element or the thermostat. Both can be checked with a multimeter after disassembly. I would normally look up the parts for you, but I can't do that without the actual model number.
