Master
- Posted on Sep 15, 2009
Re: Waterintake stops after approx. 35 sec.waterlevel is...
The machine fills by time only as you have already determined. The intake screen on the water valve is probably plugged up and cleaning it should solve your problem. You will have to turn off the supply to the dishwasher and disconnect the water feed line. Eric
what???? i have never heard of any brand of d/w that you can adjust the water fill time with the timer dial. i can only guess you are not in the USA as we dont have anything like what you are describing. the water level does not have any effect on the heating element as it will heat until the tank gets to its desired temp. you may have some other type of unit that we have never seen in the USA><
