Sewing Machines Logo
Posted on Dec 11, 2007
7570 sewing machine
Where can I get embroidery disks for phaff 7570 sewing machine
Love2Sew
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 20, 2008
Love2Sew
Contributor
Level 1:
Answers
Questions
0
Helped
351
Points
Go to ebay and buy for about $60. Better price than Pfaff and machine 7570 is a very old model.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jan 12, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
1882
Points
12
Contact a pfaff dealer in your area., and they will order what you want
What format does the Pfaff 7570 use for embroidery?
The format that is used by the 7570 and the 7560 is *.pcs or *.dst. Either one will work provided that the designs are within the confines of the hoop. The largest size design that would be embroidered by this machine would be 115 x 120 MM.
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Does Pfaff have any Disney fantasy cards for the 7570 embroidery machine
no brother has exclusive rights to disney designs look for brother 780d embroidery only machine as cheepest option
I have a 7570 phaff sewing machine and a new windows 7 PC What will I use to transfer my patterns to the machine
Hi franlove
I had the same problem when I upgraded to a laptop with Windows XP. I needed to buy a Keyspan, which connects via the USB on the computer to the machine via the pc connector that comes with the Pfaff 7570. However I had many problems after that, and found that the Keyspan transfer rate had to be slowed down to 2400. Of course 3D is the most recent Pfaff software that the Pfaff 7570 will work with. Anything older is OK.
Hope this helps. I will look up the steps that I went through to slow the transfer speed from the Keyspan if you need me too.
Good Luck
margielydia
1helpful
On what number should I put 7570 tention when
Refer to the manual. If you do not have a manual, start at 4 and work your way through the numbers, bit by bit until you get good results.
The bobbin thread should pull the top thread slightly under and to the back.
Machine embroidery bobbin thread is heavier than the standard size machine embroidery top thread and this also helps to pull the top thread to the back.
IAM LOOKING FOR THE MANUAL FOR PHAFF 545 TO DOWNLOAD CAN ANYONE E MAIL ME A LINK TO THE PHAFF 545 MANUAL OR TELL ME WHERE I CAN FIND THE MANUAL. [email protected]
545 PDF OR CONTACT PFAFF THEY WILL E MAIL YOU A COPY OR LOOK ON THERE WEB SITE FOR A COPY OF THE MANUAL . HOPE THIS WILL HELP YOU !
7570 Phaff
ITS CALLED GET A NEW 1
2answers
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
