How do I open ports in the Virtual Server?
You need to forward the ports used by the application to the server running the application
in the Virtual Server, which is present in the router's management screen, as follows.
- Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
- Click on Login, Advanced Setup, NAT, Virtual Server.
- Enter the port details and enable it as follows:
Private IP
Private Port
Type
Public Port
192.168.2.x
xxx
TCP
xxx
192.168.2.x
xxx
UDP
xxx
To access the application, you can open up the ports specific to the application in the
special application, which is present in the router management screen as follows:
- Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port
Trigger Type
Public Port
Public Type
Enabled
3724
TCP
3724
TCP
Y
6112
TCP
6112
TCP
Y
6881
TCP
6881-6999
TCP
Y
* The port numbers given are just an example. You need to open the ports depending on the
application you are using and should get the information from the application provider.
