D-Link AirPlus G DSL-G604T  Wireless Router
Problems with D-Link AirPlus G DSL-G604T Wireless Router?
Keep your PC up-to-date. Get a Free Scan for D-Link's latest driver updates.
Troubleshooting and Support
Solved Problems for D-Link AirPlus G DSL-G604T  Wireless Router RSS Feed Post a New Problem
Router d-link DSL-G604T
I've paid for premium assistance but you keep dropping me off line!
1 Solution
Still no joy in Zenithville
I have a vertical deflection failure on my Zenith Model SD2743G. I've been told to check vertical output transistors...
2 Solutions
vertical deflection_Zenith
I have an old Zenith model SD2743G that starts up ok but after a minute or so the picture becomes a single white line...
2 Solutions
Zenith Vertical deflection failure
My Zenith TV Model SD2743G Starts up fine. After about 3 min. I get a single line left to right, then picture comes and...
2 Solutions
no image
I have a Zenith SE 5221W (1989). Sound, no image. The tube is cold. High voltage circuits are evidently working (noise)....
1 Solution
D-Link DSL-G604T
Hi, Back in June, I bought a D-Link DSL-G604T modem/router and because it was noisy when the the dsl line was...
24 Solutions
Motorola..routers with cieso
Can Cisco rouetrs and motorola routers be configured with one another.............
1 Solution
Unsolved Support Problems
Unsolved Problems for D-Link AirPlus G DSL-G604T  Wireless Router RSS Feed Post a New Problem
Apple Mac
Do you know whether this works for a Mac and how to set the whole thing up.   Also each time it goes through setup...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
ConnectivityWireless
FunctionalitiesDHCP Server · Firewall · VPN Pass-Thru
Interfaces
Built-In4-port
LAN Interfaces10/100 Base-T
WAN Interfaces1 x RJ-11 for DSL
Standards and Protocols
Management ProtocolTelnet
Routing ProtocolsRIP Version 1 · RIP Version 2
ProtocolsTCP · DHCP · ICMP · ARP · UDP
Firewall / VPN
VPN ProtocolsPPTP Pass-Thru · IPSec Pass-Thru · L2TP Pass-Thru
Wireless
802.11b Data Rates11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
802.11g Data Rates54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 28 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
Modulation64QAM · 16QAM · BPSK · QPSK · OFDM · DQPSK · DBPSK · DSSS · CCK
Antenna TypeDetachable Antenna x 1
Wireless SecurityWEP · 802.1x · TKIP · WPA
Modem
Modem Max Downstream8 MBps
DSL StandardsG.Handshake (G.HS ITU G.994.1) · ADSL Lite (G.Lite ITU G.992.2) · ADSL Full Rate (G.DMT ITU G.992.1)
Other Features
LED IndicatorsPower · Activity · WLAN (Wireless LAN) · Status · Link (Per Port)
Dimensions
Depth5.59 in.
Height7.07 in.
Width1.18 in.
Weight.8 lb.
Warranty
Warranty1 Year
D-Link Contact Information
Email supportcustomerservice@dlink.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
bigg t Guru
1 solutions
Ask Me
Poohawk Wiz
1 solutions
Ask Me
micromast Wiz
1 solutions
Repair Service
