Cars & Trucks Logo
Posted on Sep 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New battery installed in 05 Solara, passenger door does not unlock when car put in park. How do I fix this?
Anonymous
Level 3:
President:
  • Master 333 Answers
  • Posted on Sep 11, 2009
Anonymous
Master
Level 3:
President:
Answers
333
Questions
0
Helped
339582
Points
1660
When the battery is disconnected, the ADL mode returns to the default setting (Mode A). The following procedure must be used to set the ADL function to Mode B whenever the battery has been disconnected.
Initialization Procedure
Perform the following procedure to initialize the ADL function to Mode B.
1. Move the shift lever into the "P" position and close all doors. 2. Turn the ignition switch to the "ON" position. 3. Within 10 seconds after the ignition switch is turned to the "ON" position, push and hold the rear side (unlock position) of the door lock switch for 5 seconds. 4. All doors will automatically lock and unlock when you release the power door lock switch. ^ This indicates that the ADL function is set to Mode B. If all doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting from step 1.
  • Anonymous Sep 11, 2009
    I apologize for the spacing being all shoved together, I'm not sure why it is doing that today!
Door lock receiver on a2001 Pontiac Grand am
Do they work with the key fob, do you have one of those? They lock when put into gear an unlock when put into park because the BCM - body control module does that .
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch
• Front Passenger door lock switch
• Body Control Module (BCM)
• Relays: Driver Door Unlock -- on vehicles with RFA, Door Unlock, and Door Lock
• Door Lock fuse 15A
Door Lock System Controls
The power door lock system can be controlled by any of the following:
• A power door lock switch activation
• A keyless entry command -- if equipped with keyless entry
Driver and Passenger Door Lock Operation
When any of the door lock switches is pressed to the lock position, the BCM door lock/unlock signal circuit changes from an idle voltage of ~3.4 volts to 0.0 volts generating a lock command. The BCM then applies battery positive voltage to the Door Lock Relay, which in turn applies battery positive voltage to the Door Lock Actuator lock circuit of all the Door Lock Actuators. Since the Door Lock Actuator unlock circuits are held to ground through the resting Door Unlock Relay(s), the actuators execute the lock command, locking the doors.
The lock function can also be accomplished by the BCM having received a keyless entry door lock command, if the vehicle is equipped with keyless entry.
Driver and Passenger Door Unlock Operation
When any of the door lock switches is pressed to the unlock position, the BCM door lock/unlock signal circuit changes from an idle voltage of ~3.4 volts to ~1.7 volts generating an unlock command. The BCM then applies battery positive voltage to the Door Unlock Relay and the Driver Door Unlock Relay when equipped with keyless entry, the relay(s) in turn apply battery positive voltage to the Door Lock Actuator unlock circuit of all the Door Lock Actuators. Since the Door Lock Actuator lock circuits are held to ground through the resting Door Lock Relay, the actuators execute the unlock command, unlocking the doors.
The unlock function can also be accomplished by the BCM having received a keyless entry door unlock command, if the vehicle is equipped with keyless entry. Keyless entry personalization allows the driver door to be unlocked individually before unlocking the passenger doors. When this feature is active, the BCM will require a repeated unlock command to unlock the passenger doors.
Automatic Door Lock/Unlock
The automatic door lock/unlock function is a Vehicle Personalization feature with the following four programmable modes of operation:
The automatic door lock feature is disabled.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON, and all of the doors Unlock when the vehicle is shifted into Park.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON, and only the driver door Unlocks when the vehicle is shifted into Park.
For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
Passenger door locks don't unlock.
You need to understand how they work , do you know about automotive electronic controls ? Your switches are just inputs to the BCM - body control module !
Door Locks Power and Ground
For door lock operation, the IP Fuse Block supplies battery positive voltage, through the 15 amp DR LK/TRUNK fuse, to the BCM. The BCM uses this circuit exclusively to apply power to the door lock actuators. The BCM is also supplied a ground circuit, which it uses exclusively to ground the door lock actuators. When a door lock is pulsed, the BCM internally connects these two circuits to the appropriate lock and unlock control circuits to actuate the locking or unlocking functions.
When diagnosing door lock malfunctions, these circuits must not be confused with the other battery voltage and ground circuits of the BCM. The appropriate wiring schematic must be used to locate the correct circuits. Failure to identify the correct battery voltage and ground circuits of the BCM during diagnosis of door lock concerns may result in misdiagnosis and unneccessary parts replacement.
When the BCM detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuators transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuators. This is done so that the driver door may be unlocked individually before unlocking the passenger doors using a keyless entry transmitter or an automatic door unlock function, if programmed. When the keyless entry transmitter is used to unlock the passenger doors, the BCM requires a repeated unlock command before it performs the unlock function. However, when the unlock input is from a door lock switch, a single unlock command is all that is required to unlock all doors.
How to test computer controlled door locks
2005 Chevrolet Tahoe Power Windows and Power Locks not working.
The power windows an power locks are controlled by a module , DDM - driver door module . As far as the locks locking when you put the vehicle into reverse an unlocking when you put the vehicle into park , that's how there are suppose to work , automatic lock an unlock feature . When you put the vehicle into any gear from park the locks should lock . Did she hit window lockout function ?
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Driver, Passenger and Cargo Door Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
• The DDM (driver door lock actuator).
• The PDM (passenger front door lock actuator).
• The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
2helpful
Hello there top of the morning to you! First of all I just bought a 2000 Audi TT 1.8T yesterday and didn't realize a few things till i brought her home from the dealer. The key fob needed new batteries so...
once you fitted new batteries to both fobs you needed to reset the car.....put key in drivers door and unlock/hold key over(windows go down)wait 30 secs then lock/hold over key,(windows go up)wait 30 secs,then press/hold unlock button for 30 secs.you have just reset the system.you have loads of other little gizmos but i will leave you to find them all good hunting....one side parking lights/driveway illumination/and more.
geoff
Lost the remote, since the alarm was activated the car wont start even though i still have the key. everything turns on except the ignition. is there a bypass. i am stuck out of town.
1.try find on the drive's foot panel or under the steering wheel,see any switch. if you find the switch trun key on position and trun off the switch. 2. put key in passenger's door Lock it and Unlock , and put key back in the ignition try to start it. 3.turn key on position and unhood the (-) battery cable for 10 seconds , put it back and start. it.
2answers
2helpful
4answers
Need to know how to adjust the door auto lock function.
Not an easy fix! The door lock function was designed to lock doors only. you can however, disable this lock feature by simply cutting the light blue automatic door lock signal wire on the 6-wire harness plug connector located on the chime module (In component center).
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Door keeps unlocking and alarm keeps coming on
it sounds like it is in the door lock actuator and the security mode itself now if you have a remote starter installed you may have to take it back to the person who installed it because the problem maybe in your security system
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
