Back to:
Tags:
D-Link DES-1008D 8-Port Ethernet Switch
Port forwarding
posted by krupal on Dec 10, 2007
helow sir... i want to know how can i forward my des-1008d d-link to maximise my download speed. inshort how to forward port on des-1008d?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 13, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
no u stupid idiots.. it does do things.. i need the port forwarding also..
stupid idiots don't give comments when u know nothing
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on port forwarding:
I don't want to Accept this solution
Solution #2
posted on Feb 08, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Your connection and modem speeds got noting to do with portforwarding
Frupal go to portforward.com theres everyting you need to know.
madansakre your and idiot
Thank You!
Solution #3
posted on Jan 05, 2008
Not Rated (0)
madansakre
Rank:Wiz Wiz
Rating: 74%, 46 votes
It depends on your connection and modem speed...
thank you..
Thank You!
Can you Help with these Networking Hubs and Switches problems?
My Requirement :- i want to access the database of a...
yellow steady, for a while after flashing all ports etc.
D-Link DES-1008D 8-Port Ethernet Switch...
how can i get this switch configuration at...
I have an N-tron 9000 that has two 9006TX's in the last...
lucas 7 SA seven pin need wiring diagram
Loading problems.
Repair Service
Find Networking Hub and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
