Kenmore 14410 Humidifier Logo
Posted on Dec 09, 2007
Filter How do i replace the filter
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 26, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
244
Points
Lift the cover, remove the old wick and place the new on in its place.
1helpful
What does the ceramic cartridge in the powerpure 3000 humidifier do and When do you need to replace.
PowerPure 3000 Ultrasonic Humidifier
This review says it has a permanent ceramic filter that cleans the water in your tank. Another review said the ceramic filter softens and cleans the water.
Amazon com PowerPure 3000 Humidifier Home Kitchen
That model appears to not require replacing the permanent ceramic filter. Other models have filters that need to be replaced.
Jan 27, 2018 • Humidifiers
Is there a filter I need to replace in the Walgreens humidifier model # 2055? Tks
Most humidifier's have a filter I would google make and model along with filter replacement you should be able to pick up a on line manual to get correct size and how to change it .
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
12helpful
2answers
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
1helpful
How do I replace the filter 14909 for the Kenmore Humidifier 758.14407
Fairly easy.
Unplug the humidifier.
Make sure the electric cord is free to move.
Remove the water tank and set aside.
Then lift the top of the console upwards. The top
just sits over the body, no latches. You will see a hood that
fits over the filters... lift this up. Filters just lift out and are
easily replaced.
At the same time, clean out the bottom pan... it gets yucky.
filter p/n is 42-14909 or E2R..available through sears.com
OR filters-now.com. Replace 2x per year
4helpful
Filter
The filter panel may be replaced from the top or bottom but it's less hassle to replace from the bottom because the top tray retains a small amount of water and also because you must be mindful of working around the feed tube assembly. Also, when replacing the filter panel, clean both trays (requires removing both trays, water feed tube and drain tube) and drain tube ... use a 8 water -1 bleach diluted solution or other anti-bacterial solution and wipe the trays and pour some into the removed drain tube (not the feed tube!) and shake it up a bit. Be careful though as you do not want bleach solution getting in your eyes, nor on your skin and clothes!
Replacement filter question
Filter part number is BCM100. Filters are sold at Sears. Also available online. Part number is listed on bottom of humidifier.
Replacement filter
You can buy them on amazon.com
http://www.amazon.com/WF2530-Bionaire-Humidifier-Replacement-Filter/dp/B0009H79HG
Or is you just google bionaire ws3560 filters and you will find lots of places on the net to buy them.
Good Luck
Feb 06, 2008 • Humidifiers
Top Kenmore Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
