Question about Kenmore Humidifiers
Kenmore Humidifier not operating?
Kenmore Humidifier model 758.154080 Alternating "F" and room humidity displayed will not stop even after water is added. Fan starts on "dry out" mode. What is wrong?
    New Friend:
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Posted on Mar 02, 2010
Here is all the info I found Ser # 50908272 Holmes Humidifier HM-300
It depends on how humid it is in the conditioned space, how well sealed the conditioned room is, and how high you have the humidifier set. If you have low humidity in your conditioned space and you are asking for a higher humidity number, it could go through quite a bit of water. If your room is not sealed well, it will allow lower conditioned air into the room and put a larger demand on the humidifier
Jan 21, 2018 | Humidifiers
Model 758743300c no humidy
'No Humidity'-- sounds like the humidifier is NOT adding moisture to the room it is running in?
Can you give us some clues?--
Like-- How is the pad look inside?
Are the fan(s) running?
are there any indicator lights lit?
Did it work for awhile, and stop?
What stopped first?-- the fans, or the little rotating wheel?
any clues that happened at the time it quite?
When was the last time the unit was opened up and cleaned out?
These devices need regular maintenance-- they build up mold and scale.
Please give us some clues to work with--
Mack B
Jan 25, 2011 | Kenmore 14416 Humidifier
760 aprilaire humidifier does not let water to the filter. I have cleaned and checked the lines in and out of solenoid.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your Aprilaire Humidifier is designed to operate in conjunction with your furnace blower motor. Most installers wire a humidifier to operate when the furnace is calling for heat. To determine if your Aprilaire Humidifier is maintaining proper humidity, turn up the heat temperature 5 degrees above the current room temperature on your thermostat and set your humidifier control to call for humidity. The humidifier control is located on the cold air return duct. To set your humidifier control to call for humidity, turn the control dial to the off position and slowly rotate the dial until you hear a “click” on the control. You should also hear a click at the solenoid valve located on your Aprilaire unit. The humidifier control will have a click point at the current relative humidity level in your home. If the current relative humidity is 45% or the outdoor temperature is above 60F, the control will only operate the humidifier in the test mode.
  1. No click at the solenoid valve indicates an electrical problem. Contact your heating and air conditioning dealer to further check the electrical components of your Aprilaire Humidifier.
  1. The click sound at the solenoid valve indicates there is electricity to the solenoid valve. By turning the dial of your humidifier control to a setting above the “click point” you should see water coming out of the drain line within a few minutes which would indicate your humidifier is working.
  1. If the solenoid valve makes a click sound and there is no water draining from the unit, this would indicate the flow of water is being obstructed.
1. To determine if water flow is being obstructed, turn the dial of your humidifier control to the off position. The first location you would want to check for an obstruction would be at the saddle valve located on the water line supplying water to the humidifier. When checking the saddle valve, you want to make sure it is completely open. This can be done by turning the valve all the way to the left. If anything is clogged, it can be dislodged by turning the saddle valve all the way to the right and back to the left. Once this is done, turn the humidifier control dial above the click point and you should see water coming out the drain line.
If water is still not coming out of the drain, check the orifice and in-line strainer to make sure they are not clogged. The orifice is located in the tube on the discharge side of the solenoid valve and the in-line strainer is located on the inlet side of the solenoid valve. You may clear the orifice by inserting a needle through the small opening. Clean the strainer by running it under warm water to dislodge deposits or replace. After clearing and re-installing the orifice and strainer (be sure to double wrench all water connections), turn the humidifier control dial above the click point and you should see water coming out the drain line.
Mar 10, 2010 | Aprilaire Humidifiers
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
Water flow from humidifier never stops. Even when furnace is off.
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Apr 17, 2009 | Honeywell HE365 Humidifier
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Humidifier not collecting water
To both, these sound like de-humidifiers. Is your goal to reduce humidity and dry your room?
If so, if the humidity is low, then the de-humidifier has no work to do. A cheap battery or dial humidistat will help.
If not, check for a clogged filter. No air moving spells no de-humidification.
Also check for a frozen evaporator coil. Same as above but this requires repairs.
Electric dehumidifiers are similar to refrigerators and window AC's. With the fan running, adjust the setting to a lower humidity setting until you hear the compressor kick in. If it does not even at the lowest setting, check the space relative humidity to make sure it has work to do. If it does, repairs may be as simple as cleaning electric contacts in controls or as bad as a refrigerant leak or compressor failure. If its bad, better to replace.
A humidifier adds moisture. If you have a humidifier and want to keep the static off your clothes and keep your nose from drying out, fill the tanks with water and add biocide.
Please do not view my comments as patronizing. Even seasoned engineers have difficulty grasping humidification.
Sep 03, 2008 | Humidifiers
Humidifiers Logo
1,856 people viewed this question
Top Kenmore Humidifiers Experts
Thomas F. Schneider
Sr. Pelo
Sr. Pelo
Marvin
Marvin
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
