It happens due to overheatting problem.When u charge the phone donot keep it in charge after u see a message in the cell phone's screen <charge complite> . And then switch off ur phone for two to three min and then on it. If after a long talking season u face the same problem u just switch off the phone and open the back cover and remove the battery and reinsert it . Then after 2-3 min on ur phone . Ur problem wil be solved
SOURCE: motorola razor
kkayy - replace the LCD or the flecable on your phone.
flauta - deri - replace the LCD
SOURCE: My motorola razor v3c the screen keeps turning white.
try a new battery or replaced the flexcable
SOURCE: When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
SOURCE: my motorola razor v3 has a white screen?
Hi, White screen on motorola razor phones can be caused by either the LCD or the flex of the screen.
First, you will need to check for the flex by replacing the flex of the phone. the flex controls the display of the phone and the keys on the keypads of the phone.
The LCD also can cause a white screen display. After replacing the flex and if it's still has white display,you will need to replace the screen.
Have a nice day.
