It should have come with an external battery charger with a wall charger.
Check the cell phone section of a department or electronics store. You should be able to find USB chargers that plug into wall outlets or cigarette lighters. You can use one of those along with the supplied USB cable to charge the camera.
SOURCE: Just purchased a Vivitar viviCam 8025. Need users
you can download the manual here: http://www.vivitar.com/products/13/VC8025%20User%20Manual.pdf
Testimonial: "It was very helpful in learning how to find each function, however it was not very helpful in describing the choices I needed to make. "
SOURCE: can i charge my vivitar vivicam 8025 with a cell
If your cell phone charger provides a USB port so that you can plug the camera into it, then yes.
SOURCE: My Vivitar Vivicam 8025 Digital Camera turned on
it is battery problem,batterydid not get charged well.replace with a new battery
SOURCE: why wont my vivitar vivicam 8025 turn on ?
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
