I lost my car stereo code. Can you tell me? My serial number of vehicle is VF31AVJZD52354689 and my car stereo is the original car stereo. Thank you for your help.
DAEWOO CAR STEREO CODES. DAEWOO Car Stereo Codes. We provide car stereo audio factory original anti-theft security codes from unit serial numbers for ...
Nissan Daewoo Radio Code. You can unlock your Nissan Daewoo radio using the 17 digit DW, DS or HY serial number. You will need to find the serial number, ...
with the radio of press and hold the 1 and 5 button then turn the power on the radio will display a serial number. call an acura dealer and tell them you need a radio code looked up. if they tell you they want to charge you for it call another dealer or tell them you run an autobody shop. it takes them less than 5 minutes to look it up
When you purchased the vehicle, there should have been an unlock code in the manual or on a card. This unlock code is related to the serial and model number of your stereo. If you lost it, contact Buick to get the code again.
Check the glove box in your car and look for a card that carry the code. If there's no card, pull the radio out and get the serial number on the side and then contact the manufacturer or the dealer and ask them the unique code for that specific serial number. They are the people that could only provide you the code.
The radio code that you need is also called the "Anti-theft" code. This code is unique with every car radio so that it would become useless once stolen.
You have the wrong stereo code. No Honda stereo code has a 0.Your local dealership parts dept. should be able to supply the stereo code given the VIN of the vehicle or serial number of the stereo.
· Turn the Vehicle ON · Go in the fuse panel · Remove the memory Fuse · Remove the Radio Fuse · Look in the Owners manual to locate the # position then Turn on the Vehicle · Wait for about 5 minutes then with the vehicle still ON put back the Fuses
If this does not work then follow the next step! · Turn the key to the ACC position · Turn On the radio · After 1 hour · The radio should give you another chance to enter in 3 more codes.
Press the Eject button and keep it pressed while you also press the power on button. Remember keeping the eject button pressed, press the power on button. “When the radio lets you put I the codes again try this putting in in these codes in the order that I give You ok” 1. 4712 2. 4323 3. 2537 4. 2283
If this still does not work you need to call the dealer! If your Vehicle was not purchased at a hyundai Dealership do not tell them so they do not refer you to the car dealer . If you describe your problem they should give you the Code over the phone… Make sure you call the 1-800 number Remove the stereo and look along the top edge of your stereo and you will see a small sticker with your serial number on it. Write this number down. If you did buy your vehicle from hyundai Dealership Write down your VIN #. Call your local dealership and give them your information They SHOULD give you your code,
Have you tried calling you nearest Honda dealer? Give them the V.I.N number of vehicle, they should be able to supply code if unit is original to this particular vehicle.
