The DS's Wi-Fi capabilities are not up to par and can unfortunately be a little fickle sometimes, and many people would rather buy another wi-fi device before trying to set it up, but if you do want to attempt to obtain your wep key so you can have wi-fi I am happy to assist you.
What you must do is get on to a computer that is hooked up to your wireless modem. From there you should be able to bring up on your system settings the information about the . Depending on what type of modem it is, you may have to flip through the more advanced information to find the wep address.
Once you do, you will have to put that code into the DS and pray that it works, because much of the time your DS will still not be able to connect.
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
