20 Most Recent
Nintendo DSi XL Burgundy Questions & Answers
I cannot get internet connections when I have internet
Hi, I am pretty sure there is a simple fix to this. First off visit this link: (http://en-americas-support.nintendo.com/app/answers/detail/a_id/6157/~/how-to-connect-to-the-internet) it has a very easy guide to connecting your DSi via wifi. Now if following that guide doesn't solve your problem don't worry. Next you would need to log in into your router. If you don't know how to do that just pick up router and turn it over and you will see its IP address and login password. Once you have logged in you will need to check if your router is allowing wireless devices to connect to it. If it isn't just switch it to allow wireless devices to connect. If you you are unable to navigate through your router that is fine, simply google your router and you should be able to find plenty guides on how to navigate your router. I hope this help you out!
No access point in range error code 051099-1
- Create a new connection:
- Trying to play online multiplayer with Nintendo DSi
- Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
- Scroll over to the third page, and select "Internet."
- Now choose "Connection Settings."
- Click on "None" for "Connection 1."
- Click on "Search for an Access Point."
- The Nintendo DSi will search for any wireless networks within range
- What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
for more help visit
https://cbrtechsolutions.net
How to change parental code on DSI-XL
- On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
- Select the right arrow twice to reach the third page, then select "Parental Controls."
- Select "Yes," to change the parental controls.
- You will be prompted for your 4-digit PIN.
- If you know the PIN, select the empty text box and enter it using the on screen keyboard, then select "OK" to continue.
- If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
- If you don't know either the PIN or the secret question, please click here.
- Select "PIN" to change the PIN or "Change Settings" to update the setting you wish to change. Once the changes are made, select "Done" to confirm any changes.
Error code 206602
from nintendo :
Error Code: 206602
Nintendo DSi Shop - Nintendo Points Card
There appears to be a problem using the Nintendo Points Card.
- Make sure you are entering the number in the correct field in the Nintendo DSi Shop.
- For Nintendo Points Card redemption, enter the number off the Nintendo Points Card in the "Add Nintendo DSi Points" section off of the main Nintendo DSi Shop page, and select "Redeem Nintendo Points Card."
- If you are attempting to add points with a Visa or MasterCard, enter your card information in the "Add Nintendo DSi Points" section off of the main Nintendo DSi Shop page, and select "Buy Nintendo DSi Points with a Credit Card."
If that does not work, please call 1-800-255-3700 so that we can assist you further
How can I connect my DSI XL to internet
go to the settings icon. find internet and tap it. depending on your modem or internet, you might or might not need advanced set up. do manual search. find the name of your internet. then, enter the security code if needed. it will make you do a connection test. if it goes right, you will have internet. hope this helps.
Turns on but blank screen
if was dropped or anything like that could cause things to pop loose , there are only tiny clips , maybe suader that hold the wires to the screen,, may have gotten knocked loose,
What does ooooFEoo mean when
I tell you just how to fix it :1. StarI tell you just how to fix itt your DSi and wait until the battery is empty. (Having an empty battery reduces the boot time. The DS has two internal flash memorys are both damaged when you have this error. With the battery under the reset is loaded while the other can not, at the same speed)2. Remove the screws and remove the battery for about 1.5 hours.Why we did this? All electricity has to be out of the system to ensure that only the information getting home I reset the tab and not the other hand, if the other can send your information, we would still have the error.3. Reinstall the battery.4.You have to be quick now: Enter your flashcard, and start your DSi.Start the application you used the last time, before the error appeared and close legitly. For the SuperCard DSTWO SNES Emulator, just press the Exit button. Other cards like the R4i to be soft reset menu flash memory card, and you need to start some game rom.5. -It is not necessary, but it just feels a little safer-Format your NDSi.6. Charge the battery and enjoy playing their new NDSi systems.- Usually, the battery replacement will solve this problem for best results, follow the steps abo
