Toshiba WRC 1000 Wireless Cable/DSL/Ethernet Router Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get to the router configuration web page to change the MTU settings?
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
11600
Points
37
If your computer is connected through your router, then you only need to type the router's IP number into a web browser. Normal numbers are 192.168.0.1 and 192.168.1.1, but occasionally they can be different.
To find it (on windows), do "cmd" from the run item in the start menu. Then, type ipconfig <enter>. The default gateway number is your router's IP.
you can configure on web.... typing the ip.
my ide will healp u vote for me
Computer hardware and networking support
Level 3:
  • Master 4,281 Answers
Master
Level 3:
Answers
4281
Questions
0
Helped
972392
Points
12566
Connect your router to 1 computer withethernet cable.
Then access it with defaults link
http://192.168.1.1
or
http://192.168.0.1
enter user name as "admin" and password as "admin" or blank or "password"
then you can configure your router.
If you need more assistanse let me know.
Thanks.
How do i change my mtu settinggs
To change the MTU rate on your router follow the steps below:
Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
Enter your username (admin) and password (blank by default).
Click OK to enter the web configuration page for the device.
Click on Setup and then click Manual Configure.
To change the MTU enter the number in the MTU field and click Save Settings.
If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
1500 is the default MTU for Dynamic (DHCP) Cable (p. 20 in user manual).
1492 is the default MTU for PPPoE (Point to Point Protocol over Ethernet) DSL (p. 22 in user manual).
Other MTU settings are listed in the manual, simply do a search for "MTU".
Note: AOL DSL+ users must use MTU of 1400.
To find the proper MTU Size, you'll have to do a special ping of the destination you're trying to go to. A destination could
be another computer, or a URL (p. 86 in user manual).
Here is the PDF link to the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
1helpful
How do i increase my mtu on my d link dir 655 router?
• Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
• Enter your username (admin) and password (blank by default). Click OK to enter the web configuration
• Click on Setup and then click Manual.Configure.
• To change the MTU enter the number in the MTU field and click Save.Settings to save your settings.
• Do a test. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
1500 is default
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Hi, my linksys WRT54GX2 has a problem, when i connect my laptop directly to cablemodem i can surf in all web pages, but when i connect my router to cablemodem, some web pages i can not open, is like the...
Try changing the MTU value of your router and see if this will fix the problem.
For Cable ISP: MTU = 1500
For DSL ISP : MTU = 1472
Or contact your ISP to set the correct MT size
2helpful
2answers
I want to change my nat type
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
2answers
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
1helpful
Cant find any options in the Web configurator about MTU!
My MTU is at 1500 and I get the same message. I don't think XBL is up yet.
3answers
1helpful
I play xbox live but i need to increase my mtu settings, how do i do this?
Under WAN configuration in the web interface of the router, you should have the option to change the MTU size. To get there, type http://192.168.0.1 in your browser. In the page that comes up , type the username / password as admin / and hit enter ( blank password )
Hope this helps
Thanks Ranjit [email protected]
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Can´t connect to certain sites
Step 1 Open your browser, enter the IP address of your router (192.168.0.1) and click OK. Step 2 Enter your username (admin) and password (blank by default). Click OK to enter the web configuration page for the device. Step 3 Click on the Home tab and go to the WAN tab. Step 4 The default MTU is 1500, to change this enter the number in the MTU field and click the Apply button to save your settings. Step 5 Test your email. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
