Re: DOES MY COLEMAN ROOTOP HAVE FILTER ON THE OUTSIDE...
You dont have a filter on top unit but you need to have your fan impeller and condensing coil clean regularly about once a year and more when your on dusty area.
Clean the coil inside and outside. try putting it in a window on a shady side of the house. I worked on a outside unit wher it was 90degrees outside but 107 degrees where it was in a hot location, close to road on sunny side of house.
It's likely that the contacts are stuck closed. You can usually just tap them with a screw driver and they will open but then you should replace them. If you don't know where they are. Find the power wires coming inside the unit and follow them. Contacts are fairly easy to replace as long as you do it wire for wire. In other words when you remove a wire from the old attach it to the new before removing another. I hope this helps. Please don't forget to give me a Fixya rating.
