how did you install your XM antenna, is it possible the GPS wire has been damaged by running it through tight spots.how did you install your XM antenna, is it possible the GPS wire has been damaged by running it through tight spots.
You can't post conmments that contain an email address.
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
You begin by setting up your existing (((XM)))
antenna the one that came in your home kit (not included in repeater package) in a location that gets good
reception of the (((XM))) signal. This may be outside, or on a south facing
window sill. This antenna gets plugged into the rear of the Delphi (((XM)))
Radio Signal Repeater Transmitter. A power jack is right next to the
antenna connection, and should be plugged in and to the wall with the
included power supply. There is also a "PWR OUT" selector switch on the
rear of the unit which allows you to control the strength of the signal
transmitted from the unit.
Once the power and antenna are attached, both
blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that
the antenna is attached correctly. It does not let you know whether
your antenna is in a location receiving a good (((XM))) signal or not. You
will have to look at the signal strength indicator on your (((XM))) radio receiver do
determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater
Antenna close to your existing (((XM))) Radio and plug it into your antenna
jack on the (((XM))) radio cradle. This connector is identical to your
(((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and
kits so compatibility is guaranteed. The Repeater Receiver Antenna does
not require any separate power connections.
Hope this helps! SATELLITE RADIO WAREHOUSE
If you have the magnetic antenna, check it for a little nick on the cable on the outside of the car where water might get in to it. A little water can short the ground and the antenna wire. You also can wash (with lots of water around where the antenna cable is) and see if it happens again, then you will know it not just the weather
My experience with the XM2Go is that it never really works well on the portable antenna -- in my case not a complete failure, but that might be because I am in an urban area there are ground transmitters in addition to satellite reception. But any movement disrupts the signal Here's the solution - record some music on myxm (up to 5 hours) while docked, and play that music when not docked to an antenna.
You didn't say which type of vehicle your wife drives, so here is a generic answer, Good luck (my wife loves her Sat Radio!)
By the way did you get any reception without the kit?
The SureConnect cables plug into the vehicle dock antenna plug and the XM antenna then plugs into the SureConnect cable. The SureConnect cable cannot be used on a retractable or motorized antenna.
If you cannot use the cable, at all, then I would go to Crutchfield, via the phone or web, as they have good technical advice. You may need a different adapter. Possibly part # 040SA10112.
