I can't figure out what is wrong with my RCA TH1101 MP3 Player. The batteries are brand new. It won't come on at all. Not even the pearl screen. It was working fine and I turned it off, went to bed, woke up and tried to turn it on and nothing happens. Plz help me
i just bought the mp3 player and when we used it, it seemed fine but when we turned it off it stayed turned off i dont know how to turn it back oni just bought the mp3 player and when we used it, it seemed fine but when we turned it off it stayed turned off i dont know how to turn it back on
AnonymousFeb 01, 2008
my pearl will turn on to the pearl screen then turn off for no reason.my pearl will turn on to the pearl screen then turn off for no reason.
my mp3 player was fine till the battery died.. then when i got new ones it would turn on to the peal screen and then turn back off... at first i thought it was that i had gotten bad batteries but later found out that that wasnt it... now i cant do any thing with it!! PLEAZE HELP ME!!my mp3 player was fine till the battery died.. then when i got new ones it would turn on to the peal screen and then turn back off... at first i thought it was that i had gotten bad batteries but later found out that that wasnt it... now i cant do any thing with it!! PLEAZE HELP ME!!
AnonymousFeb 12, 2008
i dont know how to turn the thing on and offi dont know how to turn the thing on and off
I bought a RCA Pearl mp3 player one day. It was fine the first couple of times I used it. But then for some reason it didn't want to turn on. I bought new batteris for it but it still didn't want to turn on. Please help me!!!!!!!!I bought a RCA Pearl mp3 player one day. It was fine the first couple of times I used it. But then for some reason it didn't want to turn on. I bought new batteris for it but it still didn't want to turn on. Please help me!!!!!!!!
I turn on my RCA Peal Ipod..the smaller versions you get for like 30 bucks anywho it comes on the screens changes colors as normal but there is a little lock symbol in the right corner and after the colors are done changing it says keys locked overlaping inside a circle ive tried erasing all the songs and putting them back on but the keys are still locked.....it works with one triple a batteryI turn on my RCA Peal Ipod..the smaller versions you get for like 30 bucks anywho it comes on the screens changes colors as normal but there is a little lock symbol in the right corner and after the colors are done changing it says keys locked overlaping inside a circle ive tried erasing all the songs and putting them back on but the keys are still locked.....it works with one triple a battery
You can't post conmments that contain an email address.
Turning the player on
1. Check the polarity of the battery plus (+) and minus (-), matching the indication in the battery compartiment
2. Switching the player on viewing next image, moving switch 2 towards the USB connector until the display shows up.
Are you using the cheap AAA batteries? If you are, that's your problem. Try getting some more expensive batteries or even better get some rechargeable. That's what I did with my RCA Pearl. Bought the batteries yesterday and it's still working on the same battery almost 24 hours later. hope this helps. Good luck my friend.
All u have to have is yahoo jukebox, thats the easiest way i think. Then just plug ur mp3 player into ur computer and it should pop up when u click the actions button on yahoo jukebox, then just drag the songs into the list and then hit "copy to portable device" and ur mp3 player should be listed there and then u can get the songs onto your player.
Make sure the SD card does not have a storage capacity greater than the internal memory of the Mp3 player, or the Mp3 player will not reocgnize it in many cases.
RCA TH1100 Series:
RCA TH1100 Series:
Remove and reinsert batteries - if that fails, go to RCA website for firmware upgrade - if that fails:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails, it's dead.
-Tha Mp3 Doctor
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check
http://support.rcaaudiovideo.com/downloads.aspx?product=25
for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
had the same prob with th1100 (512 mb ver) went to rca site, downloaded firmware upgrade. ran it 3 times with no result. finally checked the box "format data area" worked like a charm. hope this helps.
