Heating & Cooling Logo
I have a Sharp Air Conditioner model number CV-2P10SC. I don't have the remote for it. Can I use a universal remote for it? If so, what are the codes?
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Nov 18, 2007
SOURCE: remote code for my ge universal remote
http://www.jascoproducts.com/support/universal-Remote-codes.asp
All GE UNIVERSAL remote codes.
Anonymous
  • 41 Answers
  • Posted on Dec 21, 2007
SOURCE: universal remote code for sony TV
can you send an pic of it though my e-mail adress [email protected]
Anonymous
  • 983 Answers
  • Posted on Feb 06, 2008
SOURCE: code number to use on universal remote control on a hyundai ditital tv model hy3438
just buy another universal remote which is having teach method... by using this remote u dnt need any codes... just once use the remote by which the appliance is working for teaching it then u can do any operation...
Anonymous
  • 97 Answers
  • Posted on Jun 20, 2008
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Anonymous
  • Posted on Oct 19, 2009
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
I have a GE remote control universal remote and it is number 24922cl57252 and I want to pair that with my air conditioner which is a solace air portable air conditioner and heater how do I do it
Here are the steps to program your GE universal remote (model number 24922cl57252) to work with your Solace Air portable air conditioner:
  1. Turn on your Solace Air portable air conditioner.
  2. Press and hold the "Setup" button on your GE universal remote until the red indicator light stays on.
  3. Enter the code "991" using the number buttons on your GE remote. The red indicator light will turn off.
  4. Press the "Power" button on the GE remote.
  5. Press the "Up" or "Down" button to try and turn the air conditioner off. If the air conditioner turns off, press the "Setup" button to lock in the code.
If the air conditioner does not turn off, repeat steps 2-5 with a different code from the list below until the air conditioner turns off:
Solace Air Portable Air Conditioner Codes: 0277, 0363, 0364, 0365, 0403, 0454, 0455, 0456, 0457, 0474, 0475, 0494, 0495, 0496, 0497
I hope this helps!
We bought used sharp room air cond.it has no remote with it can we set it without remote
Will be difficult to set it whout a remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Unit runs but will not cool. Followed troubleshooting diections in manual with no luck. Wondering if there is a refridgerant recharge path which is not in the manual
recharging with gas will not be in the manual as it is done using pressure gauges and is a job for an experienced refrigeration technician
call one in as it may not be a gas problem but compressor not running or a blocked tx valve
Not cooling
Turn the thermostat down or it may be bad.
1helpful
Syncing universal remote to air conditioner
You will need the codes that came with the general remote to match the Hyundai. Hyundai air conditioners may run the same codes as LG, Sharp , Daewoo so try the codes for those as well if you don't have luck with the Hyundai code
1helpful
1helpful
E1 code
Use a universal remote (like the one for a TV) to turn on and to adjust settings. I was some what doubtful, but after trying my universal remote, my air conditioner started working.
Top Sharp Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
