Tablets & eReaders Logo
Posted on Aug 15, 2009
Somehow managed to turn laptop keyboard keys off, how do i turn them back on ?
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
2813
Points
14
2helpful
Why aren't detachable keyboard keys a/z/q working?
Some of my keyboard keys aren't working - Tom's Guide
www.tomsguide.com/answers/id-2321878/keyboard-keys-working.html
Oct 3, 2014 - My s and left shift and 1 key don't work. I'm using the on-screenkeyboard. I've opened up my keyboard, cleaned the bottom and reconnected ...
Laptop Keyboard Not Working? Here's What To Do ' PCMag ...
www.pcmag.com > Reviews > Input Devices > Keyboards
PC MagazineSep 17, 2013 - Oh no, the keyboard on your laptop stopped working! ... You'reworking on your laptop, and all of a sudden, the "I" key stops ... If you aren'tcomfortable disassembling your laptop, then bring it to a service ... With its sturdydetachable keyboard, high-resolution screen, and built-in 4G LTE capability, the HP .
Keyboard keys not working - Super User
Some keys not working
Keyboard no good. Just get a new one since you also have an intermittent situation that sooner or later will stop working permanently.
3helpful
Laptop Keys
This is because it is set to US english keyboard layout rather than UK English layout.
Go to Start -> Control Panel -> Keyboard
and change the language settings
3helpful
2answers
My keyboard wont type anything, the mouse works, but when i try to type it wont do anything, the buttons do work because when i open word to try to type if i click f the file drops down and when i click v...
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
Toshiba Portege 3500 keyboard not responding
Well, yes you do have another option.
Just press and hold the CTRL key and press the K key that should help you with your concern. If call the Toshiba hotline 1800-457-7777 to send your NB to the DEPOT.
Apostrophes key in laptop keyboard is not working, how do I fix it?
It's possible there is a mechanical problem with that key (broken, dirty).
But just in case you also use a usb keyboard with the laptop make sure that you did not disconnect (the usb keyboard) with the number lock engaged. If so you can either use the virtual keyboard to disengage the number lock or reconnect the usb keyboard and disengage the number lock. Then check if the problem is fixed when the usb keyboard is disconnected.
Typing any key on the keyboard produces multiple
hi Jeff.
go to this link should show you how to do a reset of your laptop.
How to Reset Your Computer .
or this link.
laptop basic reset Google Search
2answers
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
