I need a driver for a labtec 800 wireless optical mouse mouse was working just fine then i transported it and the computer says it can't find the driver
make sure you have the correct mouse selected control panel mouse hardware you might have to uninstall the drivers then reinstall the drivers control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot in xp hope this helps
keeping it simple-- all mice load with windows drivers first so if your mouse is not working in the most basic mode on multiple pcs the nthe mouse is dead. contact logitech for out of warranty credit.
Could be radio interference from somewhere. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring. Try the using the mouse close to the receiver, if it works ok interference is likely.
Is this a wireless mouse? If so, plug the USB connector into your computer. The pc should detect it and install the drivers automatically. Then there should be a button on the bottom of the mouse, press it, then press the button on the USB connector. This establishes a connection between the mouse and connector.
