Labtec Notebook Webcam (961401-0403) Logo
Anonymous Posted on Mar 23, 2010
Driver windows 7 for labtec webcam - Labtec Notebook Webcam (961401-0403)
Anonymous
Level 3:
  • Master 644 Answers
  • Posted on Mar 23, 2010
Anonymous
Master
Level 3:
Answers
644
Questions
Helped
218044
Points
1886
Http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
Download the nearest driver to your operating system from the url above, if you are using 64bit use vista 64bit and same as 32bit
When you first install the driver it will give you an error message, "you cannot use the current version, dont worry the setup files get extracted to a directory:
C:\Program Files (x86)\Labtec\WebCamWebInstall\Drivers\x64 or similar.
Open device manager by entering the properties of my computer find the webcam in the list it should have an exclamation mark on it, right click on it and update driver, locate the driver from a file directory as above, it has 2 sub directories, you driver is in WIM64 or 32 depending on what your system is, and press ok, it should find the driver and install it for you.
I hope this helps and let me know how you get on.
Testimonial: "thanks very much.it work"
5 Related Answers
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Aug 12, 2010
SOURCE: Windows 7/32 bit Labtec Webcam
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
The latest driver is for vista but may work in emulation for Windows 7.
micky dee
  • 3015 Answers
  • Posted on Dec 22, 2009
SOURCE: Trying to install Labtec drivers for my labtec
You can contact Labtech from here
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
micky dee
  • 3015 Answers
  • Posted on Apr 18, 2010
SOURCE: drivers for labtec webcam pro to windows 7?
Not sure about Windows 7 - you may have to download a previous OS and run the cam in Compatibility Mode
SupportByK
Khurram Shah
  • 10322 Answers
  • Posted on Mar 20, 2010
SOURCE: i need drivers for webcam live vf-0050 -windows 7
Download Free Cam Driver from this site.
Anonymous
  • 132 Answers
  • Posted on May 03, 2010
SOURCE: i need logitech webcam driver M/N: V-UBQ42 windows 7
They didn't do a good job with differentiating these ones. Easiest way to tell is by the color.
Driver for my labtec notebook webcan runing with windows 7 entreprise 32
Well you may please follow the link below -
(you can download the vista driver from the above link and then try to install it on window 7, many times it worked)
there is no specific driver for window 7
Good Luck!!
Thanks for using FixYa!!
1helpful
Driver za windows 7
Here is the link. You can download from here..
http://ptf.com/labtec/labtec+webcam+driver+windows+7/
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
1helpful
I need the windows 7 driver for the Labtec 1200 skype camera
1st You download Webcam Driver.
need the windows 7 driver for the Labtec 1200 skype cameraAfter this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
I need to update my labtec webcam/mic driver to work with windows 7 can this be done
First check the labtec website to see if they have a Windows 7 driver for it.
If not, it might be that Windows 7 supports the webcam directly, but I guess you have tried that.
Last option is to look for a compatible webcam driver for Windows 7 which is not from Labtec. This is possible since Labtec uses third party webcam components. Try using a driver finder application for that.
2helpful
Drivers for labtec webcam pro to windows 7?
7helpful
3answers
Can't get it to work on windows 7... any workarounds ?
want driver for my labtec webcam 5.1.0 for window 7 ( anthony )
1helpful
Trying to install Labtec drivers for my labtec webcam for Windows 7. It worked perfectly fine with Windows XP and Windows Vista. I updated to 7 and nothing.
Problemtoinstall with Windows 7
I could not find the Windows 7 64-bit drivers on Labtec website. However, I would suggest to download & install the Windows Vista 64-bit drivers.
Here's how to download them:
1. Go to: http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
2. Scroll to the bottom of the page to the section "Software for Labtec Notebook WebCam, Webcam Pro, WebCam Plus, plus SE and labtec® webcam".
3. From the "- Select Your Operating System -" drop-down menu, select "Windows Vista 64-bit".
4. From the "- Select Your Language -" drop-down menu, select "English".
5. Click on the "download" button to start the download.
1helpful
Updated to windows 7. labtec web cam not
HI,
There are currently no windows 7 drivers/softwares available for windows 7 from Labtec.
The only solution is to contact the Labtec support team and ask them to email you the windows 7 compatible software for your camera.
Contact Details:
44-203-024-81-61
Thank You for using fixya.
Top Labtec Computers & Internet Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
