Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
when I turn it on, water doesn't gether in the bucket but comes out of the drose hose connection....
(More)
when I turn it on, water doesn't gether in the bucket but comes out of the drose hose connection. How do I get the water to gather in teh bucket? this is for the Kenmore 50 pint 42-54501
have a manual for Models MDF 30AE - 5OAE - 40AE & 65AE EVERY ONCE IN AWHILE THE...
(More)
have a manual for Models MDF 30AE - 5OAE - 40AE & 65AE EVERY ONCE IN AWHILE THE "P1" LIGHT COMES ON....THERE IS NOTHING IN MY MANUAL IN REGARDS TO THIS. WE UNPLUG IT PLUG IT BACK IN AND IT RESUMES AT WHATEVER HUMIDITY IT IS SET FOR. WHAT IS THE "P1"??? THANK YOU CAROLINE
