My Samsung HT-TX72 home theater system will not power on at all. Thought it might be a fuse. Opened it up and sure enough I found a blown fuse.( 10amp 250 volt ceramic ) Would this be the cause? I am having problems finding a new fuse.
Check the fuse and replace the amp and those 2 big capacitors
You can try replacing it with any 10 amp fuse just to see what happens. If a new fuse keeps blowing out then you have a shorted power amplifier inside(they consist of transistor or a single chip). These device look normal most of the time short out with any visual indication. If you desolder the power amp chips(they are mounted against an aluminum heat sink to dissipate heat) and the fuse quit blowing then it is the problem.
