Try use the skype options, setup.
That will step through checking and setting up the camera and microphonr FOR SKYPE.
You need to set up you eqipment for skype.
Also check the microphone levels for your camera by right click the volume control, call up properties and select audio, make sure your camera is listed as the "recording device" and the same in "voice"
Now close the boxes and right click on volume control again this time select "open volume control" make sure "microphone" is in the list.
whilst there select "properties" then tick "recording then OK
Make sure there is a tick in "microphone here too this is important.
move the slider to about 3/4 up
If there is an "advanced" button under micropohone then click it the tone contols may be greyed out but try putting a tick in the "mic boost" and close any boxes that are open
You should be ready to try skype again you may have to make some small alterations to the recording level and the volume level for the microphone (they are two seperate things as you have just seen) but yo should be good to go
SOURCE: Webcam - Recipients can't see me.
I got this of Skype.
We are sorry to hear that you are having problems with Skype video.
Thank you for contacting Skype customer support about your video settings.
If you are using a Logitech webcam, please follow the steps below:
NB! To begin with please close Skype and make sure that you have unplugged the webcamera before installing the installation software that came with it.
1) Go to the control panel and open Add/Remove programs. Then from there uninstall any Logitech webcam software and Logitech webcam drivers from the list shown.
2) Download the latest drivers for your webcam from http://www.logitech.com/index.cfm/405/&cl=roeu,en?prodcrid=405
3) Open the webcam installer package by double clicking it.
Now select: Custom installation (advanced) and click next. You are now given a choice whether you would like to install the software and drivers or just the drivers. Please select the second option (Logitech QuickCam drivers) then uncheck 'Enable VoIP Device Management' and click 'Next'. Accept the agreements and on the next page select 'I do not want to activate this Service' (Logitech destkop Messenger). Click 'Next' and the Logitech drivers should be installed. Restart your system and plug in your webcam. Your webcam should now be correctly installed.
SOURCE: Can''t hear voice of person I call using video Logitech 9000 cam
Normal
0
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family
and friends so they have there computer setup properly.
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
) set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html
Hope
this helps. Bud
SOURCE: I have a logitech quick
Send this to them.
Normal
0
See section C. Windows Live
Messenger in the info below to setup the Audio & Video.
and friends so they have their computer setup properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
see and her to you.
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
NOTE: Your audio and
video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope
this helps. Bud
SOURCE: I can hear the other person but they can't hear me
The other teste you mention are just generic tests and didnt set up you eqipment for skype.
Also check the microphone levels for your camera by right click the volume control, call up properties and select audio, make sure your camera is listed as the "recoding device" and the same in "voice"
whilst there select "properties" then tick "recording"
Am not using the headset, just the microphone on the logitech. I am using windows XP home. My contact person had built in webcam.
1) Are you using the bundled logitech headset with the attached microphone? Or a different microphone? 2) What Operating System are you using?
