Our system BDV-E290 having push power protect flashing how i fix this problem please explained to us. reagrds
Hello Sunil, for what you comment, there may be several reasons why the term PROTECT appears on the display
There is a solution for that problem that consists of removing the humidity that forms inside the equipment, I send you the link of a video that explains how to do it
I hope you can solve the problem
Greetings Franco Dosil
Hola Sunil, por lo que comentas, puede haber varios motivos para que aparezca el termino PROTECT, en el display
Hay una soluci?n para ese problema que consiste en sacar la humedad que se forma en el interior del equipo, te mando el link de un v?deo que te explica como hacerlo
Espero puedas resolver el problema
Saludos Franco Dosil
SOURCE: How can I fix the
Easy, disable the TV speakers or turn its volume down.
http://static.highspeedbackbone.net/pdf/Sony%20BDV-E370%20Manaual.pdf
Page 36 tells you how to sync the sound to the picture but you really shouldn't have the TV speakers competing (in stereo) with the Sony. (Page 56).
A) The TV speakers are probably inferior to teh Sony's
B) When you balanced the speakers during setup there was no 'with-the-TV-speakers-on' option. The image up front would suffer by adding an unaccounted for sound source.
SOURCE: i want to program my home theater system with my
http://esupport.sony.com/perl/model-home.pl?mdl=RMTB104A
GO TO THIS DOWNLOAD FROM SONY AND PUT YOU REMOTE CONTROL FOR YOU SEARCH YOUR CODE AFTER YOU DOWNLOAD YOUR REQUIRED MODEL.
SINCERELY.
E.CUADRA
MANAGUA, NICARAGUA.
SORRY you cant , you need the remote with this system.
The Cable Guy
Sounds like corrupted firmware. Contact the authorized service center for Sony. or, visit this site, sony e-support. This kind of fault/s are not easly repairable by a user.
https://esupport.sony.com/US/p/model-home.pl?mdl=BDVE770W&LOC=3#/howtoTab
If you wish to get some details; check the site linked here. Pull up older posts.
