Aug 12, 2011 - 10 posts - 2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
un-plug it, it is not safe. i am thinking that the transformer is making the noise, probably because of the moisture.(cheap asian electronics) it could catch on fire.
It depends on if it is just a loose component that needs tightened up or if it has started failing. it will require some investigation and trial and error to resolve. I have had some success in resolving vibrations and some were real challenges. It is a matter of isolating the noise maker and seeing what can be done. Eric
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
By high-pitched, you mean it is not that same frequency as when it's cooking?
Is the tone near or the same as the beep you hear when you press a key?
Please post a little more information so we can help better.
