SOURCE: Software Problem!! Design task pane not popping up!!!!
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
SOURCE: Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
SOURCE: How to uninstall the HP Solution Center & other software
FEW WAYS TO DO IT I MEAN REMOVE PROGRAMS OR PRINTER DEVICES BOTH WAY REQUIRE TO GO INTO THE CONTROL PANEL:
SELECT PRINTER, RIGHT CLICK MOUSE BUTTON AND GO DOWN TO DELETE
AND FOLLOW INSTRUCTIONS
AND
2ND WAY
GO TO PROGRAMS AND FEATURES
OPEN THE FOLDER
WAIT FOR THE PROGRAM EXPAND
GO DOWN TO THE DRIVERS OR PROGRAM
YOU WANT TO REMOVE
THAN SELECT THE ITEM AND RIGHT CLICK IT
AND FOLLOW THOSE INSTRUCTIONS
REBOOT
EVERYTHING WILL DELETE AFTER REBOOTING THE SYSTEM AND THAN IT WILL DO SOME WINDOWS UPDATING TO HELP WINDOWS HELP WITH THE NEW CONFIGURATION SETUP OPERATIONS
SOURCE: Dell Precision 530 with dual Xeon CPUs. Uses
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
Internet
Browser Instructions
If
you open your email account using a browser, there is a very simple
way to increase the font. Font size options are located either under
"Tools" ("Options" or "Preferences"
then "Content") or "View" (text size) on your
browser's main menu. Change the font to a larger size, which may be
set by number or by selecting "Larger" or "Largest"
font from the list of options. You may have to click "Advanced"
or the similar option in the "Fonts" section of some
browsers to adjust the font properly.
Next, click "File"
then "Print Preview" on your browser's main menu. This
will show you how the email will look when printed. Click "Page
Setup" and deselect the "Shrink to Fit Page" option.
This will allow you to print the email at the new, larger font size.
Be sure to return your browser's font size to normal when you are
finished printing the email, or else all of your pages will display
with a larger font.
If
you use a non-browser email software program to view your emails,
insert your email contents into Microsoft Word (or a similar word
processing program) to print it in large letters. Select the entire
message from your email software then go to Word to paste the
contents into a blank document. You can then select the text of the
email and increase the size of the font. When you're done, print the
file as you would normally. You can also perform this action with an
email that you open inside of a browser.
