When was the last time you checked the dryer vent and tube leading out of the home? Move the dryer away from the wall. With the dryer unplugged remove the duct from the wall attachment. Use a vacume hose to reach as far into the wall vent as possible sucking out any debris. Do the same with the hose on the back of the dryer. If there's alot or it's been a very long time since it's been done, I'd suggest consulting a professional. Mine was so bad when I moved into my place, birds had nested in there. Ew
SOURCE: dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
Gas Whirlpool Style Version 2
Gas Maytag Style
Gas GE Style
Electric Whirlpool Style Version 1
Electric Whirlpool Style Version 2
Electric Maytag Style
Electric GE Style
Warning!
To avoid personal injury or even death, always disconnect your
appliance from its power source--that is, unplug it or break the
connection at the circuit breaker or fuse box--before you do any
troubleshooting or repair work on your appliance. Also, because some
components may have sharp edges, use caution while working on your
appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
SOURCE: Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
there is a reservoir in the base of the dryer which holds some condensing water prior to the pump pumping it to the holding tank at the top this has a float swith to tell the pump to come on and drain water to top tank this is probably stuck in the on position so the machine thinks it is always full of water and its waiting for you to empty it,you need to remove side panel and remove flost switch to clean, remove condenser and put youre hand in back of unit if its still very wet in there thats the problem should be bone dry at end of cycle.
hope this helps
SOURCE: Lint Filter Light comes on and cycle is interupted
I just found that the filter itself was not allowing airflow- I tested by blowing through it with my mouth- no airflow. I cleaned it with a high pressure air hose and noticed that the flow is much better now. I cleaned it by hand several times, and washing in water (which may have made theproblem).
