So i have 2 pairs of rokit 5 g3's. the first pair one speaker just stopped working (powers on but emits a warbling sound when sound is ran through) so i got a second pair, and now this pair one of them stopped working about a month ago (turns on but no sound whatsoever) so i paired the working one from the first pair with the second pair.. and now the remaining working one from Pair#2 doesnt work (turns on but makes worbling sound whenever sound is applied) ALSO NOTE THAT ON ALL 3 FAILED SPEAKERS A BIG "THUD LIKE" NOISE IS MADE WHILE POWERING OFF.. THE 1ST PAIR I HAD FOR T LEAST 4 YEARS NO PROBLEM AND NOW WITHIN A 6 MONTH SPAN I HAVE 3 FAILED SPEAKERS
SOURCE: virtual surround sound --only one
Hi bleewilke
I am afraid that you may need to do the same again. If they are getting broken at the plug end, you may be able to replace the plug, but modern cables need to be clamped in a moulded plug to retain any strength, a repair like this will probably fail also. Replacement is generally the best option. are they still under warranty
regards
Graeme
SOURCE: purchased 2 used sonance sonamp 260 for homewide
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
SOURCE: i can not get my speakers to work
cunect to the speaker go to the settings and cleack sound releted seting mention the which you have name speakers
