Televison & Video Logo
K
Koos Human Posted on Nov 12, 2018
Which output on the Smart LNB do I use for a single installation? The universal or one of the 3 Unicale outputs?
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 12, 2007
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Anonymous
  • 2559 Answers
  • Posted on Jan 22, 2009
SOURCE: HK 595 speakers
It should,but will depend on the output jack itself,If it is only a stereo output,it will only allow for a 2 channel plug.
If the output jack is for surround sound,it will work with the 3 into 1
Please rate this fixya solution.
Anonymous
  • 5 Answers
  • Posted on Oct 27, 2009
SOURCE: 2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
Anonymous
  • 189 Answers
  • Posted on May 14, 2010
SOURCE: Changed from single to twin LNB, no signal
HELLO
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
Anonymous
  • 8546 Answers
  • Posted on Feb 21, 2011
SOURCE: Home stereo issue. Pioneer VSX
Did you tell the Pioneer you HAVE a sub and run the test Tones for it and define hwo itr shares bass with the other speakers?
I need a new AC adapter for my smart radio P/N830-000099. The number on the old one is P/N:534000245. How can I get one?
Your local computer/hardware shop might stock the correct one or an equivalent/universal charger that should work.
You must take the old one with you so the person can read the output voltage, output current and look at the connector type of the old one in order to match them.
Good luck.
tip
How to Watch iTunes Movies on Vizio Smart TV?
Vizio Smart TV is one of those smart TV brands and it is also the oldest producer of affordable flat-screen televisions. If you are intending to buy a Vizio Smart TV or you are already have one, and coincidently you are an Apple user as well. Then I have to remind you that you may suffer a problem that you can't watch your iTunes movies on Vizio Smart TV. But it doesn't mean there is nothing can help you to stream iTunes movies to Vizio Smart TV.
In the next part, I will show you what is Vizio Smart TV and why can't Vizio play iTunes movies. And then you will learn how to watch iTunes movies on Vizio Smat TV.
Part 1: Know about Vizio Smart TV
Vizio Inc. is an American privately held company that develops consumer electronics. It was founded in October 2002 and nowadays it is known as one of the best smart TV brands around the world. Just like smart phone, Vizio Smart TV can allow users to surf the Internet, download various kind apps, play game, enjoy online movies as well as watch TV programs. In addition, Vizio has powerful picture performance, beautiful design and best display ability. The most popular function is that you can even use your smartphone to control the Vizio Smart TV via App.
In spite of its powerful functions, the ability of Vizio Smart TV to play videos is still limited. Vizio can't play all kinds of videos or movies if those videos are not in the right format supported by Vizio. If you are an Apple user, you will easily notice that you can't watch iTunes movies on Vizio Smart TV because almost iTunes videos are in M4V format, a video container format developed by Apple and is optionally protected by DRM copy protection. That is the reason why iTunes movies can't be played on Vizio Smart TV. According to Vizio official website, we can find MP4 is supported by Vizio Smart TV, which means we can easily watch the iTunes movies on Vizio as long as we can remove DRM to convert M4V to MP4.
Part 2: Recommendation of iTunes video to Vizio Smart TV converter-Leawo TunesCopy
According to the above we learn that only if we remove DRM from iTunes movies can we watch iTunes movies on Vizio Smart TV. Fortunately there are many video converter you can find on the Internet, but if you need a more reliable program to perform this job, I think Leawo TunesCopy is worth using.
http://www.leawo.org/tunescopy/ is a professional iTunes DRM removal program to remove DRM from iTunes movies so that convert M4V to MP4 which supported by Vizio Smart TV. Differing from other video converters, it is a single function program that only can remove DRM from iTunes videos and convert M4V to MP4. However, Leawo TunesCopy is more convenient for many Apple users than other video converters because TunesCopy can automatically import users play list. Its simple and convenient interface can help you use it easily as well.
I will show you the detail about how to use Leawo TunesCopy to remove DRM from iTunes movies in the next part.
Part 3: Guide to remove DRM from iTunes movies and watch DRM-free iTunes movies on Vizio Smart TV with Leawo TunesCopy
Before following the steps below, you need to download and install Leawo Video Converter on computer first. After installing Leawo TunesCopy program, follow the guidance you will get your DRM-free iTunes movie.
Step 1: Add iTunes Movies
Open the TunesCopy and enter the main interface. Click "Add files" button to call out the submenu in which you can select the movie you want to watch on Vizio Smart TV. And then click "Add" to import the target movie.
Step 2: Set output directory
You can change your output directory by clicking the "..." button on the left bottom corner.
Step 3: Start remove DRM from iTunes movie
After selecting the output directory click the "Convert" button and then the conversion will be started.
Step 4: Find your output movie
You can find your output movie by clicking the "Converted" section near the "Home" section. Select "Open file" option to open the target file and then you will find your output movie which has been converted to DRM-free MP4 movie.
After getting the DRM-free iTunes movies, then you can import your DRM-free movies to the USB device and connect it to your Vizio Smart TV, enjoy!
As you can see, Leawo TunesCopy is easy to use and does a good job on removing DRM from iTunes movie. Although it can't satisfy all your conversion needs like other video converters, it does have a better DRM removal experience than others. If you just want to watch iTunes movies on Vizio Smart TV, the functionality of Leawo TunesCopy is sufficient to meet your conversion requirement. Just a few steps you can enjoy your iTunes movies on Vizio Smart TV!
Hello, I have a sky dish and decoder, but before the decoder I have put a splitter and carried a seperate coax straight to another Freeview tv hoping to get a signal... But it hasnt. Is it possible to...
David.
Are you using the same output from the LNB on your sky dish?
ie one cable??.
If you are it will not work you need to use a seperate output,
if you cant do this,you will need to change the LNB to a multi output one.
By the way there is 30 volts present all the time from your receiver to your LNB, that is even while switched off.
1helpful
Dish 625 with legacy lnb
Hi beltone669,
Our 625 receiver uses DP technology. A legacy LNB would not work with the receiver. You would need either a DP Dual or a DPP Twin. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
1helpful
I have a Zinwell Quad LNB J4S which I have just got around to fitting to my Sky Mini dish and have a problem. There are 2 supplied fixing brackets only one of which fits my dish arm but holds the LMB at...
Hi, You would probably be better of getting a new dish and single 4 output LNB or you could try just ordering a 4 output LNB with a universal bracket especially for the sky dish variants, I have seen these on ebay and have used one successfully myself, I think it only cost me 20 gbp.
If you are having problems in the area with reception it may also pay to get a 90cm dish and 4 output LNB combined.
Hope this helps.
HELLO
4helpful
How do i fit a dual LNB so i can change channels
HELLO
A word of warning! Do not attempt to split any feed coming from a single output LNB to another satellite box - you will be asking for trouble!
Now for the solution. If you are using a standard sky minidish you will need a 40mm adaptor kit, a dual output LNB and another length of satellite cable (Webro WF100 prefereably) but I suppose RG-6 will do the job providing it is not too long (around 10-15 meters or so) a couple of F connectors and self-amalgamating rubber tape.
Power off everything! Remove the old LNB and to do this you'll notice a plastic rivet on the LNB arm of the dish which must be removed. When you have done that and the new LNB is place (don't tighten everything yet), connect your current length of cable to one output and the new length to the other (finger tight should be fine) and make sure BOTH of your boxes are connected. Remember to waterproof those LNB connections.
Power on! You should be getting pictures - if not the LNB will need skewing round a bit. Look at the dish from the front and turn the LNB in a clockwise position say the 2 o'clock position - that should do the trick. Then tighten everything.
I wish you well with it - good luck! (:-)
4position lnb ineed to know which termanal to hook uo to for a
do you mean 4 outputs if so it dont matter but for some reason i always use the one on the left first
Mar 19, 2009 • RCA D6520
HK 595 speakers
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
