Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Dish 625 with legacy lnb
Can I use a legacy lnb with 110 and 119 outputs with this receiver. If so, do I just connect the two cables to the two sat inputs or do I need special equipment. Used in RV ocasionally, would like to keep simple.
  • Official Brand Answer
  • 263 Answers
Hi beltone669,
Our 625 receiver uses DP technology. A legacy LNB would not work with the receiver. You would need either a DP Dual or a DPP Twin. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Posted on Apr 04, 2012
4 Suggested Answers
6ya staff
SOURCE:
raycalo
Ray Calo
  • 358 Answers
SOURCE: added a 322 reciever to
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Posted on Jun 29, 2011
SOURCE: We have an old dish network dish and LNB with a
Hi mfpayton with the install of the brand new receiver wealways want to make sure all connections are tight. And after all connectionsare hand tight we will need to run the Check Switch Test. It will provide thestrongest signal to your home and you will see the signal move up into the 65percent range. If after the Check Switch Test it still is a low signal we mayneed to check the connections from the Dish and LNB that is an issue we wouldneed to come out on. I will leave the link to show you how to do the CST.http://www.dishnetwork.com/SupportSection/complete-sig-loss
Mike Houston of DISH Network Executive Office
Posted on Jan 17, 2011
raycalo
Ray Calo
  • 358 Answers
SOURCE: switch Toshiba projection tv to receive input from video-1?
jbrowne_usa
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Posted on Mar 01, 2011
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Jun 26, 2011 | DISH Network 322 DTV Receiver
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Decoder keep scanning
well, firstly. u have a sat finder!! great!! now lets see if i can teach u how to use it, when you hook it up there will always be some sort of signal, (other electronic waves in the air) the best way to check is to put ur hand in front of the LNB (the square box in front of the dish) if he signal goes down, the signal was fine to begin with, if it goes up, the dish is out, if nothing happens... dead LNB, which in my experiance, the most likely cause, dont for get to reset your decoder once you have solved the problem.. good luck
Apr 27, 2010 | DISH Network DVR-625 DTV Receiver /...
HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE LIKE MODEL 4000 DISHJNETWORK RECIVER I FOUND IN MY CLOSET AND MY NEW DISH NETWORK RENTED DVR 625 RECIVER HOW TOO HOOK BOTH OF THEM UP TO THE 3 CABLES AND...
Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
Feb 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Receiver 510 error code 836
err 836 means you have changed your recvr to a different dish or LNB's or your missing one or more satellites needed for your installation or programming needs. if this has been in the same location and connected tot he same dish and you dont have sats 105,or 121 listed in the install summary then you will need a technician to check your dish. It could be out of alignment or a faulty LNB.
Jun 21, 2009 | DISH Network DVR 510 DTV Receiver /...
Set Up for DVR
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
Jan 16, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
I have a viewsat ultra. It will turn on.. but if I have the cable from sat in the back of the receiver,.. where it should be in sat in.. it wont turn on... but without my cable from the dish itself it will...
If you are using a switch between the viewsat and the LNB, remove it and connect the receiver again.
If that did not work, remove the cable from the LNB and power up again; if the receiver still unable to power up then you might have a short circuit in the cable itself or water might be entrapped inside the connectors on the LNB/switch connections.
Let me know if you need further assistance.
Jan 08, 2009 | Yamaha HTR-5730 Receiver
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
Viewsat ultra 2000 setup issues
You can go HERE to get all the info on how to set up your dish.
Mar 13, 2008 | Toshiba 57H84 57" Rear Projection...
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
117 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
