Hi, Dude! Oh, I'm so tired of different home electrical troubles too, but several times ago I was found the best resolution for them. On this site https://www.handykith.com/electrical-repair-nyc you can find help from real professionals in electricity from New York. They working in this sphere for many years and I believe that they can repair anything that can break. Your situation is quite simple for them and it will be solved in a few days. It is easy to solve such problems if you are working with specialists.
It definitely is a job for qualified electrician
Sounds like the timer is bad -or- the photoeye is exposed to light source... test by setting to dawn-dusk and see if it still blinks...
Following link has photoeye troubleshoot
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
SOURCE: resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
SOURCE: setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
SOURCE: I have programmed the GE
There are 6 programming buttons on face of 15117 timer.
Download pdf manual
Review of steps:
The AA battery is installed with correct polarity
Timer blinked 12:00
Set clock while holding down clock button
Press PROG to display EVENT1-on (there is a tiny 'on' that shows on display)
>day button selects day, weekday, weekend
>> hour minute buttons to set ON time for EVENT1
>Press PROG so display shows EVENT1-off (ther is a tiny off that shows on display)
>repeat steps above to set OFF time for EVENT1
>Press PROG until EVENT1-on shows in display
>repeat steps to set on-off times for EVENT2
> when finished programming, press CLOCK
> Last step, set mode
MODE is on-off override
MODE is also Automatic or Random
Solution ideas:
Press MODE until Automatic displays)
-Press MODE key to see if manual override works
-Look at digital face (or take photo of it) and compare with Figs shown in manual to see if there is a match
-Check breaker. Check light bulb. Remove timer and see if load works without it. Check that light switch is turned on if plug is controlled by light switch.
-Review programs: Push PROG key to review programs
-Other timers ignore conflicting schedules ... for example EVENT1 says
ON at 7 and OFF at 8, but EVENT2 says opposite, or overlaps, then timer
ignores programming
-Reset timer and repeat programming: Press CLOCK, MODE PROG to reset timer
-Make a chart of your EVENT1 on-off times, and EVENT2 on-off times, EVENT3-7 on-off times before programming to make sure there are no conflicts.
SOURCE: Utilitech Outdoor Digital Photocell
SearchElf - Find Utilitech Timer Instructions
Here is a link to the instructions.
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
