Hi there. Your problem is that the key dont turn, i had the same trouble and I fix't like this: First, be sure that the lever of the transmision is in the Parking position and move´t a little becouse the car have a safety lock. That should do the trick. If you still having problems, send me an e-mail to
[email protected] and I will make a video for you with mi Isuzu doing the same problem and showing the way to temporaly solving´t. About the real solution will be like this: You need to se an transmision expert, becouse the problem is a cable that works pulling over the safety lock and its conected to the transmision lever.
Another cause is the key, becouse of the use it will be getting older just like the ignition switch, but even with that I can get my car running. But even with this the safety lock, its for me, the main cause. Greetings.
