Radio Communications Logo
Edward Grady Posted on Oct 15, 2018
How to reset t5400 talkabout - Radio Communications
1 Related Answer
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jul 17, 2008
SOURCE: MOTOROLA TALKABOUT T5400
First check your batteries. Try the battery pack from a known good radio. If you do not have a battery problem, your issue is probably non-reversible. Sorry. This style radio is non-repairable. The repairable Talkabout units include the Distance, Distance DPS, the TA-7400 and TA-7200.
Manual downloads
Here's a link to the manuals http://shop.giantintl.com/Manuals.asp Choose your model from the pulldown
I've lost the back platic plate of my t5422 walkie talkie. can you buy a new one
Unfortunately, parts were never offered for the T5400 series. Your best option is to find a used one on ebay to use for parts. Sorry I could not be of more assistance.
Best regards.
1helpful
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
How to unlock it and change the channel to 1 1
You can find a user manual by choosing your radio model from the list on this page: http://www.giantintl.com/motorolafrsold.htm It will give you the instructions to program your radio.
AC/DC MISSED
The only charger shown as available for the T5400 radio with NiCd battery is the following kit: http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catProductDetail&productID=53614&&showAddButton=true
It includes the dual drop-in charger and 2 new batteries. You can order directly from Motorola at the above link.
1helpful
1helpful
2answers
Turning off distinctive end broadcast chirp on motorola 2 way radios
i have the t5600 pair and have found no way to do it but you can hold the menu button in for 3 to 5 seconds and open your selection menu that includes lock,tones,etc and on your model you may be able to turn it off. good luck!!!
Motorola Talkabout T5400
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
