Watches Logo
M
Martha Lynne Mayo Posted on Sep 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you produce windup clock, wrist watches? - Watches
Mark Cheong
Level 3:
Master:
  • Master 791 Answers
  • Posted on Sep 06, 2018
Mark Cheong
Master
Level 3:
Master:
Answers
791
Questions
0
Helped
476296
Points
2475
1 Related Answer
Anonymous
  • 79 Answers
  • Posted on Jun 05, 2009
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
2answers
Instruction manual for tagital T1 watch
Contact Tagital directly to request the manual.
Nov 28, 2019 • Watches
How do I windup my invicta pro diver 9309 watch
YOU DON'T WIND IT UP ITS QUARTZ THAT MEENS ITS BATTERY OPERATED AND PROBABLY NEEDS A NEW BATTERY
How do i work my watch?
A watch is a portable clock you usually wear on your wrist that is use A watch is a portable clock you usually wear on your wrist that is used to ... d to ...
Mar 10, 2011 • Watches
How do i change the time on the watch from a 24hr clock to a 12hr clock
mcdevito75 here, You should be able to change from the MODE button, Here is Casio contact info, 800-706-2534 Optn. 2
2helpful
With "The Producer" Nixon watch, can you reset the main stopwatch hand to zero? It resets to +4 second position.
Pull out the crown to the first or second set position then press and hold down the start button. The sweep arm should begin to move into the right position. Once it is at 12:00 or 0 release the button and press the crown back in.
1helpful
Casio cmbi watch with didgital timer and normal clock on
I lost my instruction and need to set my watch to the correct time. It is a casio illuminater AW-80
Need help with features
It only posts the water temp. Your wrist will produce body heat near the sensor making it inaccurate.
Clock just stopped ticking
best option is to take it to your local wtch repair shop and pay their small proffessional fee to have it done by someone who knows what yhey are doing
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
