SOURCE: recording 3 digit channels
With the VCR connected to DirecTV, you're not picking the channel with the VCR anymore. You're picking the channel on the DirecTV receiver, and the VCR will record on channel 3 or 4 (if you've hooked the receiver up using the RF output to the VCR) or through its line (A/V) inputs if you're using those. The tuning range of the VCR is completely unimportant.
With your new system, though, there's one big drawback. Since the VCR is always set for channel 3 or 4, or its line input, and you're changing channels on the DirecTV receiver, you can't program the VCR to record several different channels if you go out. You won't be home to change channels on the receiver, so the only channel you'll be able to record is whichever one you've selected before you go out. Remember the VCR is taping the output of the satellite receiver, and not the satellite channel directly. If you record on some channel other than the receiver's output channel, there won't be anything there. All you'll get is snow or a blank screen.
SOURCE: The remote for my TV: DX-R24TV has some how become
have you try to clean the inside contact and sheet ruber,whit wood alcool and rebuild it/ try this fist,
i hope that will help you
SOURCE: no signal onthe screen
Simple solution to my av setup that I use to connect my receiver to two monitors so I can pick which monitor I want to use for games or movies while using the other monitor for my PC. This product also solved an HDMI/HDCP issue in another room on the end of a long HDMI run into a projector. Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
