SOURCE: How To Set-Up Email Account On Prada Phone
You must set up the accounts via desktop PC (or MAC) and then you you can access via the applications or mobile web pages on your phone.
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: i have locked my experia
the truth is that you can unlock the phone ,but you can't unlock all phone for free.
The payment sites are very cheap you could try it out and see.
You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
SOURCE: i have locked my friend
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion
SOURCE: my phone is locked out...do not know google
if you remember the actual google ID, just type that and then type the password as "null" in LOWER case, once you do this you will be able to unlock the phone.
2nd solution- you have to reset your phone completely, and you will loose all the information which you had stored in the phone memory, and the SD card wont be effected by this. if its a Android 1.6 version then hold 1.VOLUME UP key, 2.SEND key, TRACK BALL, and the END key at the same time, and hold it untill the phone vibrates, this will unlock your phone
if its a Android 2.1 version, then hold 3 keys
1, volume up key
2.send key
3.power key. hold it till the phone vibrates, relese after that
select data factory reset and then select yes delete all user data, then select reboote system now. and your phone will start rebooting. and your phone is unlocked
try it... it works---- ABHI SHADS-
