SOURCE: Troy bilt 26J Mini Rider clutch sticks. How do I adjust the tension?
the pully midway from engine to deck. Look for an adjustment where the pulley articulates with the foot control. The pulley probably moves to provide adjustment control
SOURCE: 26J mini rider want start..just shut off while mowing
did you pull the spark plug and inspect the plug, check the gap is the right opening, check the wire for the spark plug, make sure it not cracked, or broken.
check the fuel, if it been seating for a while the gas could be contaminant by just seating in direct sun light, if the sun light hits the gas tank, the gas will sweat and the little drops of water fall into the gas.
check the air cleaner, just clean it dry it,
make sure a the line for the fuel are secured, not cracking, and check the hose clamps are tight so no air is getting in to the system
make sure the line are not clogged
check the for proper ground areas are clean of rust, dirt, oil, etc.
if your system has a coil test it.
www.ask.com/
www.youtube.com/
www.wikipedia.org/
/how-to-test-a-coil/
