SOURCE: Trying to sew a buttonhole
You can get all the info of alignments and features of your machine here:
Manual of your machine:
http://www.sewingmanuals.net/bernina-910-sewing-machine-service-man.html
https://www.sew4less.com/product/140/Bernina_910_Instruction_Manual
http://sewingwishlist.com/bernina.html
This information is available online but not for free.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
SOURCE: My machine Bernina 830 does not run.
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
SOURCE: Bernina 1630 needle will not move go side to side.
If you can pull the needle bar down manually and it springs back up, the basting clutch is stuck. By someone who knows how, it's a very easy fix. I would guide you here, but I don't know how to explain it. Plus, you have to be very careful not to damage the spring loaded clutch.
