SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
SOURCE: PFAFF Varimatic 6085
did you get any feedback on this machine's problem?
i'm getting the same model by the end of the week.
thank you. chuck
SOURCE: Pfaff triptronic 2040 sewing machine
Could be a couple of things:
Hope this helps.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
SOURCE: how do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
