SOURCE: no forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
SOURCE: no forward or reverse. lights
Joe with a scooter there can be a number of things wrong to cause your problem Since the motor turns and you have power at the console. It could be the throttle pot or the speed pot or both or it could be the cable that runs from the console to the rear of the scooter and finally a problem with the controller. But that would also give some sort of error to the console light if it is equiped with a power light. If Medicare paid for your scooter then they will pay most of the cost of repair. Your provider can work on it for you or they can contact a repair service that will fix it for you Hope this helps
SOURCE: turn it on-battery fully charged, worked a week
Check the conections on the battery and drill aren't tarnished.
This is a common problem which prevents drills from operating.
The contacts can be cleaned with very fine sandpaper.Don't rub too hard or you will remove the chrome plating on the contacts.
SOURCE: 1998 48V electric club car
If you go to www.studmonkeyracing.com/forums/cc48v.jpg you will find a schematic for what I believe will be close to wiring of your cart. A systematic check of volts to the various components should get you going. 1st port of call, you should see 48 volts on both sides of the keyswitch when it is on. Check the fuse in line with the red wire from the solenoid to the on-board computer.
It may simply be that you have one battery terminal too loose and it just wont allow you to draw enough current to run anything but the buzzer. Does the buzzer stop when you press your foot on the gas? If so it really does point to a loose battery connection.
SOURCE: my sons gator lost reverse,
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
