Computers & Internet Logo
f
frances rang-chenoweth Posted on Mar 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I select a movie the small circle just keeps running and movie never starts
Ian Center
Level 2:
Sergeant:
  • Expert 258 Answers
  • Posted on Mar 10, 2018
Ian Center
Expert
Level 2:
Sergeant:
Answers
258
Questions
31
Helped
44622
Points
683
Computer needs a cleaning or it is your internet connection or provider. Go and check your internet speed by typing Internet speed test in your browser and test to see how fast or slow your internet is running. If the internet is slow it will most likely run movies slow online and we call this buffering witch we all hate but it is do to slow computer or an upgrade needs to be done threw your internet provider.. Good luck hope this helped....
tip
How to create motion across the screen?
Step 1
Create a small circle to the left in the Stage area. Do this by selecting the circle tool from the left toolbar. Draw the circle in the Stage area.
Step 2
Select the Arrow tool from the left toolbar. Double-click on the circle to select it.
Step 3
Now we have to convert the circle to a symbol. When the circle is converted to a symbol we can create instances of the circle. From the top menu choose Modify > Convert to Symbol. Name the symbol "Ball", and select OK.
Step 4
Go to Frame 10 in the Timeline. Do this by clicking the gray field below 10. Then right click in this field. Choose Insert Keyframe. Keyframes appear as circles in a frame. This operation duplicates the image.
Note: A keyframe specifies changes in an animation. You create keyframes at important points in the Timeline and let Flash create the frames in between.
Step 5
Select the circle and move it to the right a couple of inches.
Step 6
Click on the Timeline any place between Frame 1 and Frame 10. Then right click and choose Create Motion Tween.
Step 7
Choose Control > Test Movie from the top menu to test your Flash movie.
My ps2 won't read dvd movies. I put them in and nothing happens. even when i click the browse selection. It plays the games just fine, but doesn't seem to read the movies at all.
you need to have a modded ps2 to play pirated movies which are not official copies if you are using an original dvd copy then try keeping a weight say a small mobile charger or a small book on the ps2 if you are using the slim ps2
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Games or movies wont play icon keeps moving in circle
This is very common. You have a bad BluRay laser diode. Discs can sometimes transfer a very small amount of static electricity. That can short out a laser. You will need to get the laser replaced by a tech or send it back to Sony if it's still in warranty.
Thank you!!
After burning a movie on computer i play it back on my playstation audio is intermitten but sounds well when played in other dvd devics
Region hack for the old driver:
Method 1:
Hold down L1, Circle, and Select while booting until movie starts
Method 2:
Press in L3 (the left analog stick) straight and hard until movie starts
Region hack for the new driver:
1: Start the PS2, enter the Browser
2: Insert DVD, wait for the CD icon
3: Select the CD Icon
4: Press Square and keep it down
5: Press Circle and keep it down (Do not release Square, you should now be pressing two buttons)
6: Wait for the DVD menu
7: Release the keys
8: Start the movie with the play icon or the movie start icon
HOW TO USE THE CAMERA
Hi Sonali,
To record movie clips first of all press the menu button, this will refelect the shooting menu of your camera, select the first option of shooting modes by the navigating keys circling the menu/ok button. Then press the right arrow on the navigating keys, this will open the modes of shooting. Generaly while first use always AUTO is selected, you may scroll up to select the movie mode and then press ok button. Now you are ready to record clips. Click on the shutter button (picture button on the top of the camera) to start recording clips and when you are done re-click to stop recording.
I hope this will help ;-)>
Regards
Premanshu.
Nokia n95
That circles mean the progarm is running. The n95 keeps apps running in the backroun. To see the apps running u can go in to the menu and look for the circle, or u can press and told the menu key this will give u a list of the apps. U can also exit the programs from this by hitting the clear key. If you press the end key or exit the progarm with out hitting the exit button then it will keep running.
Can't forward to a scene in the middle of a movie
When this Sign comes up it means that you cannot Forward.
You usually get this at the start of some dvd movies.
It is basically to stop you forwarding through the advertisements.
Ive never (YET) seen this (Logo) in the middle of a film denying you to Fast-Forward to a particular point or where you SHOULD be able to select a scene.
I can only presume this Film you have is either a pirate(IM NOT suggesting that you deal with pirate copies)
or a foreign movie.
3helpful
7answers
Blackberry 7290 issue
my blackberry 7290 keeps saying device error:400 then below says reset i keep reseting it and nothing comes but it keeps saying reset .. wat can i do ?
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
