I have tried 27 codes but all have failed, The original remote control died. I have purchased a ONE FOR ALL changer URC7115. Many thanks.
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
gemni3 quick 50 codes for samsung tv
SOURCE: i need remote control codes for a Sylvania VCR/DVD
hi! i have here a couple of codes for your sylvania DVD/VCR just try them, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095. hope this helps!!!! goodluck!!!
SOURCE: small universal remote control 'TOTAL control' brand
I downloaded the complete user manual for free at Forum: www.remotecentral.com
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
OK.
000,003,004,005,
007,009,011,
015,048,082,092,
094,096,098,
101,102,103,107,
113,125,129,
167,179,187,188,
191,194
3-digit code.
