Cars & Trucks Logo
y
yubandran Posted on Jan 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi audi a3 2.0t bwa two faults p2127 and p2122 what can cause this problem
Bill Boyd
Level 3:
Top Expert:
  • Audi Master 53,816 Answers
  • Posted on Jan 31, 2018
Bill Boyd
Audi Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950797
Points
172802
Code p 2122 has three reasons
1--accelerator pedal position (APP) sensor---switch D--low input==causes wiring short to ground --APP sensor /switch
2---throttle position(TP) sensor /switch D--low input===causes ---wiring short to ground--TP sensor/switch
3---engine control module (ECM) idle control---high input===causes --wiring short to positive ---TP sensor---ETS control module
code p 2127 refers to APP sensor--switch E--low input===causes wiring short to ground --- APP sensor/switch
also refers to TP switch E--high input====causes wiring short to ground ---TP sensor switch
2 Related Answers
Anonymous
  • 6468 Answers
  • Posted on Jul 09, 2012
SOURCE: Check engine light is on, reduced power displayed on dash, code P2122 and code P2127 comes up
its a problem with the pedal and throttle position corilation
Testimonial: "Thanks, I replaced the throttle positioning sensor (had to buy a whole new gas pedal as the sensor is in the pedal. Pretty easy fix, two 10 mm bolts and used a small screw driver to release the wiring harness. Replaced in about 10 mins. "
kas982
Kas S
  • 140 Answers
  • Posted on Apr 29, 2016
SOURCE: 04 Dodge Ram 2500 turbo diesel Cummins 5.9 - had tranny rebuilt, when I put in drive it will take off about 10 yards and stop I have to restart to go another 10 yards getting codes P2122 & P2127
well the codes are for throttle sensor, possibly a lose wire/electric connection when refitting unit.
Car not taking the gas,code p2122 and p2127
check your aps sensor,accelarator position sensor if its bad and make sure all connector and wire from this sensor to ecu is good,.
1helpful
Code p2122 & p2127 any solution?
The pedal position sensor is throwing a code. could be ECM may need to updated
Accelerator pedal position sensor
have the throtthle body cleaned and then decide if you need it replaced may be dirty
9helpful
Korean chevy problem
need to diagnose the BCM for codes ,too. the car with a lock signal indicates a security system fault. that would explain the dying after 3 seconds because the ecm has turned the fuel injectors off.
2helpful
2answers
I have a Nissan Frontier with accelerator & throttle problems. I have sensor codes p2122 & p2138. How do i fix this problem? Is it a self fix problem? HELP!
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I hope this helps you and thank you
2helpful
Check engine lite is on, power lost lite is on. code p1276comes up. replaced throttle body, but no change. volts at vac fuse 14 both sides. will not accelerate over 1800 rpm's. 2004 trailblazer with 6cyl.
Your CODE P1276 refer to the Acelerator Pedal Position, Sensor 1 Circuit Range Performance.
Probable cause: Wiring, APP or ECM
GM - P1271 Accelerator Pedal Position Sensor 1-2 Correlation
I also found this... though its for Trailblazers... but may give you a clue:
Reduced Engine Power Message and/or Check Engine Light with any Combination of the following DTCs: P0107 P0112 P0122 P0452 P1120 P1220 P1221 P1271 P1275 P1280 P1481 P1515 P1540 P1633 P1635 P1639 P1682 #PIP3192 - (Oct 18, 2004)
Reduced Engine Power Message and/or Check Engine Light with any Combination of the Following DTCs: P0107 P0112 P0122 P0452 P1120 P1220 P1221 P1271 P1275 P1280 P1481 P1515 P1540 P1633 P1635 P1639 P1682 PCM Repeat.
The following diagnosis might be helpful if the vehicle exhibits the symptom described in the PI.
Condition/Concern:
Reduced engine power message and/or check engine light with any combination of the following DTCs: P0107 P0112 P0122 P0452 P1120 P1220 P1221 P1271 P1275 P1280 P1481 P1515 P1540 P1633 P1635 P1639 P1682
Recommendation/Instructions:
If the SI diagnostics did not isolate a concern, the following information may be helpful:
- Inspect the main engine wiring harness between the PCM and the generator assembly for a potential short to ground. There is a metal wiring harness retainer in this area that secures the main engine harness. If the harness conduit is mispositioned, some of the wiring may become exposed and chaff on the harness retainer. This may eventually cause the exposed circuit to short to ground.
- Inspect the 3 harnesses that connect to the PCM for potential shorts to ground on the metal PCM mounting bracket, just below the PCM. There are plastic harness retainers on the PCM bracket that secure the harnesses to the PCM bracket. If the harness conduit is mispositioned, some of the wiring may become exposed and chaff on the PCM bracket. This may eventually cause the exposed circuit to short to ground.
- If a chaffed circuit is found in either of the above locations, repair the circuit using the necessary SI procedures. Once the circuit is repaired, tape the area of the affected area of the harness to prevent the wires from becoming exposed in the future and secure the harness using the original harness retainer.
This applies to 04:
- 4.2L 5.3L LL8 LM4 Engine with DTC - P2120 or P2122 or P2123 or P2125 or P2127 or P2128 - kw low MIL pedal power reduced #PI01746 - (Feb 17, 2004)
- 4.2L 5.3L LL8 LM4 Engine with DTC - P2120 or P2122 or P2123 or P2125 or P2127 or P2128.
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
MIL light on. Reduced Power message on DIC. Possibles DTCs P2120 and/or P2122, P2123, P2127, and P2128.
The APP harness is clipped to the accelerator pedal bracket. The harness may chaff on the upper portion of the accelerator pedal causing a short to ground. Verify the harness is not chaffing on the accelerator pedal. After repairing the short, reposition the harness to ensure no contact between the harness and the accelerator pedal.
Hope helpes.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
