The plastic attachment which houses the cable is broken, can this be replaced.
Hi.
If the plastic guide is broken, I suggest you replace the complete window regulator,it broke because it must have
wear on the rest of the plastic guides as well.
I have seen very few of those parts sold online, but like
I said just replace the regulator with a new one and have the peace of mind that it`s not going to break again tomorrow.
Hope this helps
Testimonial: "thank you for your suggestion, but what part of set up is the regulator."
SOURCE: side mirror glass replacement
If it is just the mirror that is broken & not the mount, locate a wholsale auto glass distributor & they will have the replacement mirror. Typically under $20.00
SOURCE: How to replace the Passenger side Rear View Mirror on door.
there should be a plastic cover on the inside of the car where the mirror is take this off and there will be a connector block unplug this and there should be screws undo them and the whole thing should come off themn and you should be able to seperate them then.
SOURCE: dirver side mirror broke today
ok first you need to pull the little trianglle off the back of the mirror on the INSIDE of the door
when you do this you will see 3 bolts...remove the bolts and unclip the harness...you can go to a junkjard and get a new mirror cheaply and installation is reverse of removal
SOURCE: 1991 corolla door rod handle plastic clip broken
You can get inside door handle either new or used from sellers on ebay. It should be just a few dollars plus shipping. Just search ebay for "Inside door handle 1991 Toyota Corolla."
Frank
Frank's Friendly Cars Maui Car Rental
www.MauiCarRental.biz
SOURCE: The brackets that attach to
Hello, normally just the window sashes break. this is the plastic part that is glued on the bottom of the glass. you can but these asahes at your dealer. they simply just glue on with a special glue
Sash Channel Came Off Glass; Adhesive on Glass
Cut off the bottom edge of the guide with a cut off wheel. (Refer to the illustration above.)
Using a thin flat blade putty knife and a hammer, carefully remove the plastic piece on each side of the glass. (Refer to the illustration above).
22689012
Sash, Side Door Window
12378568 (US)
88901676 (Canada)
Structural Urethane Installation Adhesive
